will having 2 80mm fans blowing in from the side in the front corner and 2 60mm fans in the front blowing towards the back be ok? I have to put the 80mm fans blowing directly onto nothing because theres nowhere else to put them and i need them to achieve balanced intake and exhaust. I cant put them above my cpu and video card area because I put my window there and I do not want my sexy window to be blocked with 2 fans in the middle. So...will having 2 fans blowing against the opposite side wall of the case disrupt airflow from the 2 fans in the front (and in general) or will it be ok and all the air from these 4 fans will just head to the back and top blowholes, passing by my cpu on the way? Also, I have one weaker 80mm that I am thinking about placing inside the middle of my case blowing air from the lower front to the back top straight at the cpu hsf. What do you think? Thanks.
