a disadvantage of using a monitor for video and audio?
mikeymikec
21,340
16,553
I tried this out on my server / home theatre PC, which is connected to a TV via HDMI for audio and video output - have audio playing, set Windows power options to switch the monitor off after a minute.
After the minute, the TV displayed 'no signal', and of course it lost the audio feed as well.
I'm surprised that I haven't encountered / thought of this before. I doubt that this is purely a disadvantage of HDMI, surely the same thing would surely occur if one used a monitor connected via say VGA as well as analog audio out.
Can anyone confirm this? While I can't imagine myself ever using a monitor to play music (ie. I've had a hi-fi connected to my PC for about 15 years), I sometimes leave music playing on my PC while I work nearby. I guess the workaround is easy enough for the average person, simply buy a set of active speakers.
VirtualLarry
56,587
10,225
Nope, that's pretty much just a feature / "quirk" of HDMI outputs. Cut off the video, it also cuts off the audio stream, since they are essentially combined (I guess?).
If you had been hooked up via VGA, then setting monitor display timeout to one minute, would have caused the monitor to shut off, but if you had analog audio speakers connected to the onboard, they would keep playing on.
mikeymikec
21,340
16,553
I meant, VGA monitor using speakers integrated into the monitor.
sdifox
100,849
18,071
This is an issue with hdcp. some devices are good at renegotiating on resume, some are not. Change input then switch back usually fixes this.
VirtualLarry
56,587
10,225
I don't see where the OP says anything that would indicate a HDCP problem, do you?
