I appreciate your help! Here they are:
1. Where can I find the Technical Reference Manual for the IBM x31 (or more specifically, for model 2885-PWU)
2. What size and type of harddrive is used in the x31? I have a 40gb currently inside, and want to upgrade to 60 or 80gb. I know that they are 2.5" drives (pretty sure, at least). Is that all I need to know in order to purchase one? Or are there other variables that I need to consider.
3. When I get the appropriate drive, what is the best way to copy over the hidden partition? I want to preserve the X31's awesome recovery system that has the factory install hidden away on a seperate partition, available with the click of a button. Do I need special software to do so? Also, I was planning on buying a USB hard drive enclosure so as to connect the new hard drive via USB and somehow mirror my current drive onto it - then go on and physically replace the new one for the old.
Thanks a bunch for your help in advance.
