RaynorWolfcastle
Q1 - CPU steppings: What exactly is the difference between two steppings of a chip? I imagine it has something to do with making minor changes to the process, but what kind of changes are typical? How do those changes help a chip achieve higher freqs?
Q2 - CPU binning: When Intel and AMD 'bin' a certain chip for a certain speed, do they only test it for stability at a certain speed or do they also take heat output into account? Do 2 same stepping CPU's that function at the same frequency generate necessarily generate the same amount of heat?
-Ice
-Ice
