I just built a system with the P4C800-E Deluxe board, and I have a couple of problems. I'm sure I've seen them both mentioned on here before, but I just searched through the threads and couldn't find anything.
First, I'm getting system freezes, accompanied by the HDD LED on the case being constantly on. These seem to mostly occur when there's a lot of disk activity going on (eg installing from CD), but I've also had one while idling in Windows. It hasn't yet happened when I've had an application running. I have a 120Gb Seagate 7200rpm SATA drive connected through the ICH5R controller; is it worth moving it to the Promise controller and seeing if that makes a difference, or is the problem likely to be elsewhere?
Second, the onboard LAN doesn't seem to be working. I suspect this is a software rather than hardware problem: I've installed the drivers etc and Windows seems happy, recognizes the device, etc. I tried to use it at a LAN last weekend, but when I connect to the switch, no flashy lights, can't connect to anyone else's computers. I assumed it would just work straight off; are there some other settings I need to fiddle with?
Thanks for any help you can provide.
System:
Asus P4C800-E Deluxe
P4 2.8Ghz
2 x 512Mb Corsair XMS 3200 TwinX
Seagate Barracuda 120Gb SATA
Enermax 460W PSU
Hercules 3D Prophet 9800 Pro
LiteOn DVD
LiteOn CD-RW
Hercules Fortissimo III sound card
Windows 2000 Professional
System:
P4 2.8Ghz
Enermax 460W PSU
LiteOn DVD
LiteOn CD-RW
