A couple CPU cooling questions.
AndyBogard
89
I'm about to start building a new computer, its going to be Athlon 64 socket 939 PCI Express computer, I'll be using a 3500+ Newcastle processor. This will be my second computer build. I'll also be using the stock HSF. I'm not going to overclock, at least not right away, I'm still a noob to OC'ing, but I would like to keep my processor as cool as I can while still using the stock HSF.
When I go to mount the HSF on the CPU, do you recommend that I take off the thermal pad and use AS5, or is the thermal pad ok (this is if it uses a thermal pad)?
If I have to remove a thermal pad on the HSF so I can use AS5, what do you recommend I use to get the thermal pad off, and what do you recommend I use to clean the heatsink?
Would it be alright to remove the stock fan and put a different fan in its place (thinking about replacing with a Panalfo or something of quality that will do a better job and still mount to the stcok HS)?
Also what size is the stock fan on those heatsinks?
Any recommendations or advice is appreciated. Thanks.
BlueWeasel
15,944
475
I'm not sure about the size of the heatsinks on the 3500+.
Definately take off the thermal pad, as using good thermal paste like AS3/4/5 is much better than the thermal pad. Do this will likely help to lower your temps by a few degrees. Just be sure not to "goop" the paste on the processor...you only need a thin layer. Do a search for "Artic Silver application" if you need some help.
Removing the thermal pad is easy if you use 70% iso. alcohol and razor blades. Be sure to clean the surface thoroughly so none of the thermal pad remains.
o1die
4,785
If you're not going to overclock, there's no need for using a different heatsink. You can also use the thermal pad that comes with it. If it's too noisy, you can use a zalman "fan mate 1 or 2" device to lower the fan rpms. I run my p4 at 2550 at idle, but I would recommend 3000-3200. But try the cool and quiet feature first. It may lower fan rpms automatically.
