I'm using a win98 se system and a folder was deleted containing several important files (don't ask). The folder was moved to the recycle bin, and the bin was then emptied. Since then nothing has been done with the system, no defrag, no heavy disk use, it's just sat there. Is there a way to restore the folder and all the files? I've heard that getting Norton Utils would work and I can unerase them. Is there any other way to do it? Is Norton the best bet?
Thanks!
- Tony
Thanks!
- Tony
