- Jun 30, 2004
- 16,876
- 2,190
- 126
There is another fairly current thread here in which I crossed paths with someone rocking 2x GTX 980 in SLI. Comparing notes on my 2x GTX 970 SLI setup, we concluded that we had the same SLI quirk.
And we had done proper, clean NVidia driver installation for version 347.52.
These GTX 970/980 cards are supposed to settle down to a power-saving mode with 7 to 10% power consumption for each card, and core/memory of about 135/350 (more or less).
When we enabled SLI in the NV Control Panel, the GPUs settle to this aforementioned P-state. Upon re-boot, the GPUs are running at 40% power-consumption and ~ 912/3000. To get it to behave properly, you then have to disable, then re-enable SLI.
So there are two folks I know of so far at Anandtech who've described this anomaly, and there was another enthusiast forum where it was being discussed. IF . . . that forum was the NVidia forum, I'm sure it has NV's attention, but I cannot remember.
If your SLI'd Maxwell cards exhibit the same problem, please create an account for yourself at NVidia's web-site, and submit either a bug report or a tech-question submittal suggesting it as a bug-report item, but asking for a resolution to the problem if NVidia has the answer for fixing it at the user end.
I'm not eager to download the latest Beta driver, and I'd like to get past this . . . little . . . imperfection. Maybe this has been more extensively discussed here, but my exchange with our forum colleague here elicited his mild surprise. I wouldn't know.
But the Maxwells run at least 10C cooler in normal 2D usage and consume as much as 80W less at the wall when they're behaving properly.
Also -- if there's some tweak that could be made through NVidia Inspector, which exposes the P-states of the cards -- if someone knows of something like that which preserves the full speed capability when the cards are under load -- I'd like to hear it.
