I have been to a million sites that suggest tweaks for your system if you have a cable modem. I've even checked dslreport's tweak-detector thing and it said my machine was totally tweaked. Well, it was WRONG!!!! I actually found this on a Warez bot, and downloaded it for fun.
Here's the numbers------
before i applied the tweak, i would get anywhere from 800Kbps to 1.5Mbps. Afterwards, I got anywhere from 3Mbps to 4.8Mbps!!!!!!!!
here's the tweak, it's a registry hack--
go to this key-
[HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\VxD\MSTCP]
and create a new string value called DefaultRcvWindow, and set it to 64240.
If you are not comfortable editing the registry, simply open notepad, copy the following and paste it in.
(start copying)
REGEDIT4
"DefaultRcvWindow"="64240"
(stop copying)
and save it as a file with the extension .reg
now just double click it and it will say "the registry was successfully updated" or something to that extent.
let me know how well this works for you, it worked AWESOME for me!
and no, i am not a door to door salesman!
EDIT: sorry, i forgot to mention that you have to reboot for it to go into effect!
go to this key-
(start copying)
REGEDIT4
(stop copying)
