Hi guys,
It's summer and my 2004 Acura RSX Type S is leaking water on the passenger side carpet again. I've checked and rechecked that the drain tube is clear and it seems fine. I've watched water drip from there when the A/C is on, and it has been cleaned a few times just in case, and the problem remains.
The water is clear, cold, and doesn't smell like antifreeze or anything else. Last summer I started to pull out the glove box and center console to try to find the source but I never managed to pin it down other than it's coming from inside the foot vents there.
I guess it's something inside the A/C core (not sure about terms here) but I'm not sure if I should try to open it to keep looking for the source or what.
Any ideas or suggestions on what it might be or how I should attack this problem from here?
