So I went through 2 or 3 pretty detailed guides and am finishing up the OCing project with my Opteron 165.
Since it was my first time OCing I want to make sure I did everything perfectly and not to fry my CPU.
First my computer specs:
Opteron 165 CCBBE 0610DPMW
Abit KN8 Ultra (nForce 4 Ultra)
2x1GB Patriot PC3200 LL Stock: 2-3-2-5 @200Mhz (Will go up to 209MHz at stock timings. 2.5-3-3-6 @ 230MHz -> not the maximum, but I didn't want to make the timings go too high.
OCZ Powerstream 520W SLI
"Max" CPU -> 2.9GHz @ 1.55V @ 59 or 60 C. Obviously will get hotter and probably too hot during this NC summer weather.
"Max" HTT/FSB -> 335
"Max" Memory -> Haven't found it, but it will do 2.5-3-3-6 @ 230MHz
I used this calculator to find what settings I should put my CPU at:
http://math.gogar.com/athlon64.cgi
I am thinking of 2.8GHz so I plugged in these values. Please correct me if I made a mistake plugging in the "correct" values!
CPU: 2800
RAM: 230
HT: 1000
HTT/FSB: 335
MULTI: 9x
So it churns out this huge chart with the best choice at the top:
311 9 x 311 = 2799 17:24,141,DDR283 = 215.3 (DDR431) 3 x 311 = 933 0.4093
My main question is did I plug in the correct values for the calculator and what should I put in the bios?
For now it seems like I set the CPU Multiplier to 9x -> FSB to 311 -> Memory to DDR283 <- is this correct? -> HT ratio 3x.
Edit: Another question. I have a OCZ 2x1GB PC4000 Platinum Edition ram kit (3-3-2-8 stock). Should I really use these rams instead of the Patriot sticks? It is obvious that the timings are going to be A LOT better at higher MHz, but how much better is it than the Patriots?
Edit:Seems like I found a better one?
280 10 x 280 = 2800 5:6, 166, DDR333 = 233.33 (DDR467) 3 x 280 = 840 0.0008
CPU: 2800
RAM: 230
HT: 1000
HTT/FSB: 335
MULTI: 9x
