- Oct 11, 1999
- 25,195
- 0
- 56
I got frustrated with the info leaking out on the Nexus One, here's someone that's a bit more tech savvy that got to use one for a few minutes:
Also confirmed is a 3.5mm headphone jack.
I'm looking forward to it, and will likely buy one when it's available, although I may wait till they offer a good price, or snag one from eBay.
I just played with the Google Nexus One for a few minutes, Heres my report:
- Its extremely thin
- Its much nicer looking in person than in pictures
- Theres a 4 GB micro-SD card installed
- The battery capacity is 1400 mAh
- The screen appears to be OLED (same size/resolution as the Motorola Droid)
- 3G works on T-Mobile USA
- I can confirm that theres no 3G on AT&T (EGDE only)
- Its definitely unlocked
- Its super snappy! Faster than the Droid
- Theres no multitouch support in the browser or in Google Maps
- Theres no dedicated camera key, but its the same camera interface as the Droid
- The trackball can be used to focus (like on other HTC devices)
- Low-light performance is decent, but the flash is weak
- Calls are routed the normal way, not using data (VoIP), and sound fine
- The home screen is divided into 5 panes (like the custom interface on the HTC Hero Motorola CLIQ)
- Its using a micro-USB connector for data/power
- There are some gold contacts at the bottom edge, for a dock perhaps?
- Did I mention its fast?
