A bit of hardware humor
LintMan
474
I found this on the comp.arch newsgroup back in 1990 and saved it. It still cracks me up now, and the megahertz remark seems quite relevant still...
Anyway, the setup for this is that the first poster mistakenly writes .5k (500) for the number of transistors instead of .5M (500,000). The next guy sees this and jokes about it, and the last guy takes it up as a challenge to design a 500 transistor 32-bit CPU...
In article <1990Dec15.021854.7613@d.cs.okstate.edu> minich@d.cs.okstate.edu (Robert Minich) writes:
>by rcpieter@svin02.info.win.tue.nl (Tiggr):
>> The ARM is a good example of a RISC with very few transistors (core is < .5k
>> transistors). The reason is that its designers wanted it to be CHEAP.
> Wow, 500 transistors for the core. Must be one of those RidiculISC
>extremists. :)
Okay, the software engineers demand a 32 bit processor, and the bean counters give a 500 transistor budget. Overconstrained? Let's give it a try.
A bit serial approach is selected. This results in meager instruction throughput, but makes possible an extremely high clock rate. Since most of your market believes computer horsepower is measured in MHz, sales will take off. The sluggish performance will have them back as repeat customers within a year.
The serial adder with carry flip-flop is just a few dozen transistors. Data path multiplexers and logical instructions cost four transistors each. Special locations in main memory will substitute for operand registers. So far it looks like 500 will be easy. Unfortunately we need a full size memory address register to form those 32 bit addresses for the bloated software. A 32 bit instruction pointer probably requires a hardware register too, but we can economize by storing it on dynamic nodes next to the memory address register. The control section has a 6 bit counter to keep track of all those shifting microcycles.
Instructions. Let's splurge and have four independent ones: ADD, NOR, STORE, and JMPNEG. One addressing mode: direct. The hardware will need just 2 bits of instruction register, and the rest of the instruction format can gate directly into the memory address register. Oops, that's looks like only 30 bits of word addressability. Here a byte, there a shift, and in come the orders for the commercial instruction set option.
The customer's consultants must never see the raw hardware instruction set. Some of them would complain bitterly about having to teach the computer to subtract, multiply, and divide (probably because they don't remember how) and our machine could get an unfavorable reputation. Base level assembly language is verbose, convoluted and ugly. Wrap two layers of microcode around the machine to emulate a sophisticated instruction set.
The first layer of microcode emulates arithmetic, stack, index registers, and memory mapping. Level 1 assembly language is concise and effective. The second layer of microcode implements call gates, virtual machines, capabilities, and something we can call object oriented. Level 2 assembly language is verbose, convoluted, and ugly, but the consultants would feel like members of a high priesthood.
PUTTING IT ALL TOGETHER
Function..............Bits@Trans......Subtotal
full-adder............1@28.............28
nor...................1@4...............4
shift-register........33@8............264
dynamic-latch.........33@2.............66
multiplexers..........40@2.............80
counter...............6@18............108
control-pla...........n/a.............100 est.
Total Transistors......................650
The design is running 30% over budget. The bean counter wants to compare die size against the competition to see if they have a cost advantage.
i486 Die:
|..0....0....0....0....0....0....0....0....0....0....0....0....0...0.|
|0##################################################################.|
|.##################################################################0|
SPARC Die:
|.0.0.0.0.0.0.0.0.0.0.0.0.0.0.|
|0###########################0|
500T Die:
|.00000000000.|
|0...........0|
|0...........0|
|0...........0|
|0.....#.....0|
|0...........0|
|0...........0|
|0...........0|
|.00000000000.|
Our yield is expected to be quite good. Note that the die size is limited by the bond pads for the address bus. There is opportunity for a cost-reduced variant with multiplexed address bus.
500SX Die:
|.0.|
|0#0|
|.0.|
The bean counter is ecstatic! Yield is 99.9% and a tested die costs only .3 cents. In quantity 10000 it sells for less than a bypass capacitor. The package looks like a transistor. Rumor has it that some are marked 2N500SX to get around the export ban to the Soviet Union.
Robert Heiss rob@wilbur.coyote.trw.com
MichaelD
31,528
Woah. Way, way over my head. :Q But bump 'ya for someone who can understand this and appreciate it more. me\<---on the way to library to get smart on this stuff.
notfred
38,241
4
lol, I like the instruction set with four instructions :)
I hope they never need to read from memory :)
CTho9305
9,214
lol :D thats great. hmmmm.... i wonder why it took intel 11 years to implement it ;)
lets see... does it do interrupts? ;)
i second (or third, or whatever) the recommendatoin to post in HT :D
LintMan
474
i wonder why it took intel 11 years to implement it :D
lol @ CTho9305!
Sorry guys - I spent too many years studying computer architecture in school and didn't quite realize not everyone wouldappreciate instruction set and shift-register humor. :)
I could explain it all, but it probably wouldn't be worth it...
CTho9305
9,214
LintMan - YGPM (you've got pm). I could do an undergraduate research project on something related to this :D
edit: heheh... that also explains the "heat spreader".... gotta hide that ultra-tiny core ;)
