A bit of an Adware problem
Menalaus
86
So my first Adware problem in a few years and I also can't get rid of it. I've run AVG and Spybot and both find the adware in question, and both claim that the adware is quarantined/deleted, but I still get pop ups. The only real problem is that it uses Internet Explorer, so that means every time I run Steam, then it allows an opening for the adware to pop up (because I only use Firefox). I've tried to fiddle around with the IE security settings at the highest possible setting and I've also tried deleting IE, but it seems like I can't.
So I guess my question is how exactly do I go about deleting/completely blocking IE? I don't use it, I don't need it, and I don't want it.
CalvinHobbes
3,524
If you haven't read the sticky at the top of this forum, do so now. It contains lots of information to help you get rid of the problem.
I don't think there's a way to uninstall or remove internet explorer but you can try google to see if there is.
humanure
441
you should be able to remove ie using your windows disc, check under "remove windows components" and look for ie
Menalaus
86
Logfile of Trend Micro HijackThis v2.0.2
Scan saved at 10:54:05 AM, on 12/7/2007
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v7.00 (7.00.6000.16544)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\LEXBCES.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\system32\LEXPPS.EXE
C:\WINDOWS\arservice.exe
C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
C:\PROGRA~1\SYMANT~1\SYMANT~1\DefWatch.exe
C:\WINDOWS\eHome\ehRecvr.exe
C:\WINDOWS\eHome\ehSched.exe
C:\Program Files\Common Files\LightScribe\LSSrvc.exe
C:\Program Files\Common Files\Microsoft Shared\VS7DEBUG\MDM.EXE
C:\Program Files\Autodesk\3dsMax8\mentalray\satellite\raysat_3dsmax8server.exe
C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
C:\PROGRA~1\SYMANT~1\SYMANT~1\Rtvscan.exe
C:\WINDOWS\system32\PnkBstrA.exe
C:\Program Files\Viewpoint\Common\ViewpointService.exe
C:\WINDOWS\system32\dllhost.exe
C:\WINDOWS\system32\wscntfy.exe
C:\WINDOWS\Explorer.EXE
C:\PROGRA~1\SYMANT~1\SYMANT~1\vptray.exe
C:\Program Files\Drag'n Drop CD\BinFiles\DragDrop.exe
C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\MOM.EXE
C:\Fraps\FRAPS.EXE
C:\WINDOWS\system32\ctfmon.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\ccc.exe
C:\Program Files\BitTorrent_DNA\dna.exe
C:\Program Files\DAEMON Tools\daemon.exe
C:\Program Files\Viewpoint\Viewpoint Manager\ViewMgr.exe
C:\Program Files\Common Files\Nero\Lib\NMBgMonitor.exe
C:\WINDOWS\system32\wuauclt.exe
C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
C:\Program Files\Common Files\Nero\Lib\NMIndexStoreSvr.exe
C:\HP\KBD\KBD.EXE
c:\windows\system\hpsysdrv.exe
C:\Program Files\iTunes\iTunesHelper.exe
C:\Program Files\iPod\bin\iPodService.exe
C:\Documents and Settings\agamemnon\Desktop\HiJackThis.exe
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Bar = http://ie.redirect.hp.com/svs/...bd=PAVILION&pf=desktop
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKCU\Software\Microsoft\Internet Connection Wizard,ShellNext = http://ie.redirect.hp.com/svs/...bd=PAVILION&pf=desktop
R3 - URLSearchHook: (no name) - {D73F49B6-B51B-4d32-A3B7-BD04B8342F53} - C:\Program Files\MorpheusBar\SrchAstt\1.bin\MBSRCAS.DLL
O2 - BHO: Adobe PDF Reader Link Helper - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: MorpheusToolbar BHO - {3F3714A1-89A4-46be-8AF3-D0C9D1FB03F9} - C:\Program Files\MorpheusBar\bar\1.bin\MORPHBAR.DLL
O2 - BHO: (no name) - {53707962-6F74-2D53-2644-206D7942484F} - C:\PROGRA~1\SPYBOT~1\SDHelper.dll
O2 - BHO: SSVHelper Class - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O2 - BHO: Viewpoint Toolbar BHO - {A7327C09-B521-4EDB-8509-7D2660C9EC98} - C:\Program Files\Viewpoint\Viewpoint Toolbar\3.8.0\ViewBarBHO.dll
O2 - BHO: (no name) - {D73F49B1-B51B-4d32-A3B7-BD04B8342F53} - C:\Program Files\MorpheusBar\SrchAstt\1.bin\MBSRCAS.DLL
O3 - Toolbar: Morpheus Toolbar - {3F3714A9-89A4-46be-8AF3-D0C9D1FB03F9} - C:\Program Files\MorpheusBar\bar\1.bin\MORPHBAR.DLL
O3 - Toolbar: Viewpoint Toolbar - {F8AD5AA5-D966-4667-9DAF-2561D68B2012} - C:\Program Files\Common Files\Viewpoint\Toolbar Runtime\3.8.0\IEViewBar.dll
O4 - HKLM\..\Run: [HPBootOp] "C:\Program Files\Hewlett-Packard\HP Boot Optimizer\HPBootOp.exe" /run
O4 - HKLM\..\Run: [vptray] C:\PROGRA~1\SYMANT~1\SYMANT~1\vptray.exe
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [Drag'n Drop CD] C:\Program Files\Drag'n Drop CD\BinFiles\DragDrop.exe /StartUp
O4 - HKLM\..\Run: [SunJavaUpdateSched] "C:\Program Files\Java\jre1.6.0_03\bin\jusched.exe"
O4 - HKLM\..\Run: [StartCCC] C:\Program Files\ATI Technologies\ATI.ACE\Core-Static\CLIStart.exe
O4 - HKLM\..\Run: [amd_dc_opt] C:\Program Files\AMD\Dual-Core Optimizer\amd_dc_opt.exe
O4 - HKLM\..\Run: [NeroFilterCheck] C:\Program Files\Common Files\Nero\Lib\NeroCheck.exe
O4 - HKLM\..\Run: [NBKeyScan] "C:\Program Files\Nero\Nero8\Nero BackItUp\NBKeyScan.exe"
O4 - HKLM\..\Run: [axis web cake second] C:\Documents and Settings\All Users\Application Data\Book Slow Axis Web\free blue.exe
O4 - HKCU\..\Run: [Fraps] C:\Fraps\FRAPS.EXE
O4 - HKCU\..\Run: [Steam] "c:\program files\valve\steam\steam.exe" -silent
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O4 - HKCU\..\Run: [BitTorrent] "C:\Program Files\BitTorrent\bittorrent.exe" --force_start_minimized
O4 - HKCU\..\Run: [BitTorrent DNA] "C:\Program Files\BitTorrent_DNA\dna.exe"
O4 - HKCU\..\Run: [DAEMON Tools] "C:\Program Files\DAEMON Tools\daemon.exe" -lang 1033
O4 - HKCU\..\Run: [WinZix Service] C:\Program Files\WinZix\wakeservice.exe
O4 - HKCU\..\Run: [Part Remote] C:\DOCUME~1\AGAMEM~1\APPLIC~1\Upseek\BlehAbout.exe
O4 - HKCU\..\Run: [BgMonitor_{79662E04-7C6C-4d9f-84C7-88D8A56B10AA}] "C:\Program Files\Common Files\Nero\Lib\NMBgMonitor.exe"
O4 - .DEFAULT User Startup: Pin.lnk = C:\hp\bin\CLOAKER.EXE (User 'Default user')
O4 - Global Startup: Adobe Gamma Loader.lnk = C:\Program Files\Common Files\Adobe\Calibration\Adobe Gamma Loader.exe
O4 - Global Startup: Adobe Reader Speed Launch.lnk = C:\Program Files\Adobe\Acrobat 7.0\Reader\reader_sl.exe
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.6.0_03\bin\ssv.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~1\MICROS~2\OFFICE11\REFIEBAR.DLL
O9 - Extra button: Internet Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra 'Tools' menuitem: Internet Connection Help - {E2D4D26B-0180-43a4-B05F-462D6D54C789} - C:\WINDOWS\PCHEALTH\HELPCTR\Vendors\CN=Hewlett-Packard,L=Cupertino,S=Ca,C=US\IEButton\support.htm
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O15 - Trusted Zone: http://*.trymedia.com (HKLM)
O16 - DPF: {0E5F0222-96B9-11D3-8997-00104BD12D94} (PCPitstop Utility) - http://pcpitstop.com/pcpitstop/PCPitStop.CAB
O16 - DPF: {4F1E5B1A-2A80-42CA-8532-2D05CB959537} (MSN Photo Upload Tool) - http://by109fd.bay109.hotmail....resources/MsnPUpld.cab
O16 - DPF: {BE833F39-1E0C-468C-BA70-25AAEE55775E} (System Requirements Lab) - http://www.systemrequirementslab.com/sysreqlab.cab
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
O23 - Service: ATI Smart - Unknown owner - C:\WINDOWS\system32\ati2sgag.exe
O23 - Service: Autodesk Licensing Service - Autodesk - C:\Program Files\Common Files\Autodesk Shared\Service\AdskScSrv.exe
O23 - Service: AVG Anti-Spyware Guard - GRISOFT s.r.o. - C:\Program Files\Grisoft\AVG Anti-Spyware 7.5\guard.exe
O23 - Service: DefWatch - Symantec Corporation - C:\PROGRA~1\SYMANT~1\SYMANT~1\DefWatch.exe
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: LexBce Server (LexBceS) - Lexmark International, Inc. - C:\WINDOWS\system32\LEXBCES.EXE
O23 - Service: LightScribeService Direct Disc Labeling Service (LightScribeService) - Hewlett-Packard Company - C:\Program Files\Common Files\LightScribe\LSSrvc.exe
O23 - Service: RaySat_3dsmax8 Server (mi-raysat_3dsmax8) - Unknown owner - C:\Program Files\Autodesk\3dsMax8\mentalray\satellite\raysat_3dsmax8server.exe
O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - C:\Program Files\Nero\Nero8\Nero BackItUp\NBService.exe
O23 - Service: NMIndexingService - Nero AG - C:\Program Files\Common Files\Nero\Lib\NMIndexingService.exe
O23 - Service: Symantec AntiVirus Client (Norton AntiVirus Server) - Symantec Corporation - C:\PROGRA~1\SYMANT~1\SYMANT~1\Rtvscan.exe
O23 - Service: PnkBstrA - Unknown owner - C:\WINDOWS\system32\PnkBstrA.exe
O23 - Service: Viewpoint Manager Service - Viewpoint Corporation - C:\Program Files\Viewpoint\Common\ViewpointService.exe
End of file - 9658 bytes
