A Alpha Pal with a 2500 RPM 80mm....
Regs
16,666
21
Well I recently received a Alpha Pal HSF with a Thermaltake 80mm fan. Once I actually got the thing installed I looked at the tachometer and it registered as 2500 RPMs. It is silent however... isn't a 2500 RPM 80mm fan suppose to be for case use? I know with a 80mm fan it has more air flow however 2500 RPMs seems a little to weak. Will a 3200 RPM make much of a difference? I am running 48-50c idle right now, during a game maybe 52-54c.
beatle
5,661
Which Alpha, the 8045? 2500 is not bad for a case fan. I run a 2500 rpm Panaflo M1a on my overclocked tbred with good case cooling. Those temps you list aren't too bad.
Regs
16,666
21
8045, yes. And the 2500 RPM thermaltake is on the heat sink not the case. I also have the fan blowing outward.
Palek
937
For the 8045, there is about a 1 or 2 degree Celsius difference between suck and blow mode, so it really does not matter which way the fan rotates. As for the fan speed, it depends on your CPU, but a 2500 rpm 80 mm fan should be enough for up to 1800+ XPs - don't take my word for it though. I have an Alpha 8045 on my 2400+ which previously donned a Delta screamer on top running at 4000 rpm, and it provided more than sufficient cooling, so I presume 2500 rpm could be enough for a 1800+. (Although 3000 rpm would be more ideal just to be on the safe side...)
I hated the noise, so I replaced the 80 mm fan with a super-slow 120 mm model. It raised temperatures a few degrees, but the CPU can take it, and it is sooooo quiet!
oldfart
10,207
I run an Alpha 8942 on a P4 2.6 @ 3.34 GHz with a Panaflo M1A 80mm fan. Works fine and is very quiet. I ran a 80mm L1A 1900 RPM on my 3.06 GHz CPU which was also great. No need for lots of noise!
Regs
16,666
21
Whats your CPU temps and room/case temps, oldfart ?
On a 80 degree day like today, my cpu runs around the 52c mark. Since my case isn't exactly top of the line, I think it would be best for my fan to be blowing on the heat sink rather away.
Seems like no matter what I do, I can't keep this cpu cool.
KillaBong
426
I would have it suck air out because it was designed for it. There is very small space between the little prongs and sucking seems to be like 1-2 degrees cooler. I personally use the 4000rpm delta, and it keeps my processor at about 35-45 depending on how long/intensive it has been working.
HiTek21
4,391
I have an Alpha Pal 8045 heatsink with a Vantec Stealth fan on it, 27cfm at 21dBA. It runs about 2200rpm with idle temps around 48 - 50 and 54 - 56 under load. Case temps are around 28 - 30c. A lot of people say for the higher end heatsinks you need to run a high CFM fan to get the best results. Also I tried running the fan both direction Exhaust and Blowing and I get better results with exhaust.
If you lap your heatsink might be able drop your CPU temps by a few degrees but don't expect a whole lot more.
Chaotic42
35,216
2,359
I use case fans for my CPUs. Since I have two, I take any chance I get to cut down on the noise. It's a nice low hum. I had an 8054 and I could actually run it for quite a while with no fan. I did have a 119CFM (IIRC) Delta on it though. Kept it at 32C under load. ;)
