PLEASE when you POST threads asking for input on system builds tell us...
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
For a family member and spouse who download music and play FPS games like CoD: Black Ops. They also play WoW.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Trying to stay below $1000.
3. What country YOU will be buying YOUR parts from.
USA, New Egg mostly I suppose.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Intel for the CPU. others I'm flexible on.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I have a new Corsair TX750w lying here in box unused so I figured I could use it to save some money. Kinda overkill for this build but waste not want not. It could prove useful down the road if they ever want CF/SLI.
6. IF YOU have searched and/or read similar threads.
Yes, and will continue to read and research.
7. IF YOU plan on overclocking or run the system at default speeds.
No, no overclocking. This couple knows nothing about overclocking and giving them that could be troublesome I feel. LOL
8. What resolution YOU plan on gaming with.
Probably 1920x1080. Seems like most new monitors coming out with that.
9. WHEN do you plan to build it?
In about a week depending on sales and/or shipping times.
10. Don't ask for a build configuration critique or rating if you are thin skinned.
Okie dokie.
This is for a daughter and spouse. She likes to download music and play WoW which he does as well but he also likes FPS games like CoD: Black Ops. Basically looking to build them something that will play A Title games for the next couple years at least. I figure 2-3 years down the road I can upgrade it for them. I thought to keep costs down and avoid any possible problems to go with a non-overclocking system. Keeping it simple. His gaming laptop is going on 3 years old so he needs something better.
Here is my preliminary build idea.
CPU-Intel i5 2500 - $209.99
http://www.newegg.com/Product/Produc...82E16819115073
The i5 2500 is about as good as it gets and price wise is not horribly bad. Considered a i5 2400 but concerned it may not be enough power for later as system ages. Also to help save money planned on going with stock retail cooler. No overclocking so should be fine.
Mobo-AsRock H61M-VS - $59.99
http://www.newegg.com/Product/Produc...82E16813157241
Saw this suggested in another build. Its a low end budget mobo thats cheap. USB3 is not required so should work. I haven't read anything bad about it. Not many reviews exist though. Not against going with another choice as long as its reliable and stable.
RAM-4GB is plenty for gaming and what not. - $38.99
http://www.newegg.com/Product/Produc...82E16820231425
This RAM is what NE had suggested to go with the mobo above. Pretty cheap. Not against other brand or choice as long as its reliable and works.
Case-Antec 300 - $69.95 - $10.50 instant = $59.45
http://www.newegg.com/Product/Produc...82E16811129042
I considered the Vulcan and Elite 341 mATX cases but then decided since I'm using a non-modular psu and may need to go ATX later on that the 300 would be more suitable. Its an older design case but still very useful and popular for today's rigs. I'm open to better ideas.
PSU-Corsair TX750w - Already have it.
As I mentioned above I had this sitting around unused and felt I could save money by using it. Its rather overkill but later on if I upgrade the system to something better it could prove to pay off.
CD/DVD- Sony Optiarch - $19.99
http://www.newegg.com/Product/Produc...82E16827118039
Need a simple burner/player. Used Sony before and they're fine. Blue ray not needed.
HDD-Samsung Spinpoint F3 - $64.99
http://www.newegg.com/Product/Produc...82E16822152185
1TB should be enough for them to start off with. This hdd is popular and pretty good. I could get something cheaper I suppose but I'll go with this as a base suggestion. I think it will work with the mobo chosen. *Note: No SSDs will be used in this build. Too expensive and not needed IMO.
O/S- Windows 7 Home premium 64bit OEM - $99.99
http://www.newegg.com/Product/Produc...82E16832116986
All they need I believe. Comes with SP1.
GPU-EVGA GTX460 - $169.99
http://www.newegg.com/Product/Produc...82E16814130570
A 460GTX or a ATI6850 would be a good start. This card is about the best bang for buck in the $150 range. I was hoping to get price down enough to a ATI 6950 or it's nVidia equivalent but that won't be easy without making compromises. The upside is that later on they could get a better card and upgrade. Xmas is not far off. LOL
Monitor/LCD- 22" - $159.99 - $40.00 Instant = $119.99
http://www.newegg.com/Product/Produc...82E16824262011
This Hanspree seems to be good enough. With the rebate it is pretty cheap right now. Not against going with something else. Hoping to stick with 22" as size. Need not be 1920x res.
Speakers- Logitech X40 2.0 - $27.99
http://www.newegg.com/Product/Produc...82E16836121002
I chose this unit simply because I have a set for my SFF rig and they work well. Might be able to find something else to save some money or something better.
Keyboard-Lite On - $7.99
http://www.newegg.com/Product/Produc...82E16823107128
Nothing fancy. Cheap. Useable.
Mouse- Logitech MX518 - $44.99-$10.00 instant = $34.99
http://www.newegg.com/Product/Produc...82E16826104178
A mouse is a very personal thing IMO. Not everyone likes the same types/models. The MX518 is a good one though so I thought I would try and get him one. Money could be saved here by going El-cheapo standard usb mouse.
Case fans-Scythe S-Flex 120mm $19.99 x 3 = $44.97 (save $5)
http://www.newegg.com/Product/Produc...82E16835185006
The Antec 300 has room for three additional case fans. I should get at least two but planning for three. I want to make sure there is good airflow since I was planning on not getting a after market HSF for the CPU. I have used this particular model before and like them. Currently sold out at NE but I can find them somewhere I'm sure.
That is pretty much it. A complete system. For around $960. Any pricing, rebates, and combo deals subject to change of course. Although everything above is listed as non combo. Curious to see what the good folks here at AT can do to help me out. Of course I'm open to better ideas and suggestions.
Okie dokie.
