My system...
IC7-G / 3.4C / 1GB PC3200 (nothing OC'd)
Original HD I tried to Ghost - 36GB Raptor with XP Pro.
Current HD running 160GB Seatgate with XP Pro.
While running the Raptor I attempted to Ghost (OEM that came on the SystemWorks 2003 Pro CD), my Raptor drive onto a 39GB partition on the Seagate.
During the reboot to do the ghosting, Ghost failed to complete the cloning. The menu options seemed simple enough, one option was to exit Ghost and boot into Windows.
The only problem was that it wouldn't do anything after I chose that option.
There were different things I tried to get to Windows, but even F8 couldn't get me past the stupid Ghost DOS startup. I finally gave up and just loaded Windows onto the Seagate manually. Now I'm just trying to extract my data from the Raptor...
* With the Raptor set as slave to the Seagate, I can access the files/folders.
1. Is there any way I can "uninstall" Ghost from the Raptor while it's set as a slave to the Seagate?
2. In order to get rid of Ghost (and possibly reboot the Raptor into Windows as master again), would simply deleting the Ghost folder, allow me to do that?
