I recently upgraded to the latest and greatest shiny.
So of course I decided to test the system.
I'm using y-cruncher stress tester and CPUID HWMonitor to monitor temps. Stock settings, no overclocking whatsoever.
And I'm somewhat concerned that I'm seeing temps to the tune of 115 °C on the package and well into the 90s for all cores (98°C max on a few of them). And I'm seeing a bit of thermal throttling, cores dipping below the advertised 4700 MHz all-core load.
For reference, my cooling setup is my trusty old CM Hyper 212 evo in a push-pull config (the old fan didn't fit with the new ram I got, too high, got in the way, so I got a slim noctua and moved the other fan to the back of the cooler).
I've been looking at reports that say that cooler is rated at 150W, but the 9900K is generating in excess of 200W (even tho intel advertises it as 95W TDP, fat chance). HWMon reported max Package power of 308W, which is like double the rated capacity.
Should I be worried (I realize probably not, but asking just to be safe)?
Alternatively, How good of an idea is it to get a new cooler? (If yes, Recommendations please.)
All told, if the numbers HWMon is reporting are to be believed (200W steady state thru most of the test, and a 150W rating on the Hyper 212), it seems to be performing remarkably less thermal throttling than I expected.
