Unfortunately I had a leak and one of my cards burned or both I didn't check the other one.
Anyway both of my cards are(were) water-cooled and both have slightly different blocks but it works. The first one was designed specifically for the Titan and the other slightly longer was marked as a FC block for the 780Ti but it works with the Titan. So they didn't change the stock coolers and the position of the mounting holes is it still the case with the 980 TI? It uses the same cooler(almost) so there is a chance. Are the mounting holes the same?
ps. The block are EK FC.
