9800XT heatsink on a 9800pro 128mb?
Apr 15, 2004
4,143
Some of the 9800pros use 9800XT PCBs, such as This One, so does anyone know if a 9800XT heatsink can be mounted on these cards without any modifications? If you enlarge the picture it looks like a few components may be in the way, but I can't tell for sure until I can find a picture of a 9800XT with the heatsink removed. I'm sure it could be made to fit either way if you need to do a little cutting with a dremel, but that's a pain in the ass.
I need a single-slot cooling solution since I own a Shuttle XPC, right now I'm using an Evercool VC-RE and the XT heatsink looks like it'll do a much better job of cooling the GPU, but I don't wanna take a chance and order one of these cards to find out it won't fit when I can grab one second hand and save some cash.
