The 9800SE ? 380/340?.256bit bus has L shaped memory configuration 2.8ns memory. The 9800SE 325/250 ? 128bit bus ? has I shaped memory configuration 4.0/3.6ns memory.
I would really avoid 9800SE?s as they are IMO really junk (unless I was pretty well guaranteed a softmod to a 9800pro which only the faster version of the 9800SE can do.). I have no idea why ATI produced 9800SE?s. IF the 9800SE was somewhere between the 9500/9600pro and 9800np in performance it might be a decent card. But as it is, the 9500pro is a little faster than the faster version of the 9800SE and a lot faster than the slower version.
