9800pro owners:
mettleh3d
330
I pulled all my fans except the CPU n GPU and it still has a high whirring noise. i never thot it was the video because, well, i dono. I stopped the 9800's fan with my fan and BAM. silence. well, near silence.
the 9800pro is the only thing keeping my system from near silence. =/
i dont wanna spedn money to fix it. not worth it.
Elcs
6,278
Personally, I never noticed any audible difference between my Sapphire stock cooling and the Zalman VF70-0 Cu.
Perhaps the stock fan is dieing.
Jeff7
41,596
20
Originally posted by: foofoo
hi,
this cooler is actually very quiet and easy to install
plus it's only $15
http://www.svc.com/vga-rev3.html
there are a lot of threads on it. search for arctic cooling.
good luck
Got the same one - quite nice, and very quiet. They've got more specialized versions, but they're longer. I had tried the the ATI Silencer 1 Rev 2, which is 21.5cm long. The VGA Silencer rev3 is only 18.5cm. The ATI Silencer 1 didn't fit in my Antec SLK3700AMB case, which has 5 HDD's in it - the ATI Silencer hit the hard drive. Modding it wouldn't have helped either, not without slicing up the fan blades. I wound up selling it and getting the VGA Silencer.
Elcs
6,278
So why did you switch to zalman? did you OC ur card?
Stock cooling was starting to run really hot. I want this 9800P to last me at least 8 months so I figured the Zalman would keep it from consuming itself.
vamirr
15
First thing I did was remove the small fan and point a quiet 80mm fan at the stock heatsink. Very cool and quiet now. Nothing but hate for small fans. =)
