- Jan 7, 2012
- 107
- 0
- 0
I have a '98 civic EX coupe with around 160,000 miles. The car was mechanically running perfectly fine ever since I have had it, only issues were minor such as window motors, etc.
The oil was changed with it's usual 5-30 full synthetic and a mobil 1 oil filter less than 200 miles ago. It was completely full of oil this whole time.
I was driving at about 45 mph when the car suddenly dies and I was barely able to coast into a safe spot off of the road. Now that I think about it, the car engine did seem to start running substantially louder (kinda like you are really low on oil when the engine just seems a little bit "ticky"), but this was only for a few seconds before the car died.
The car wouldn't even try to start. I tried hitting the alternator with a metal rod I had in the back. This made the car start to turn over or almost start, but not quite.
Last night I had the alternator changed. The car cranked right up. The engine makes a horrible knocking noise like there is metal in the engine synced perfectly to the RPM's. At low RPM's it is a knock, at high RPM's it is a grind.
What could it be and why???
Edit: The car has no check engine codes
