Hi there,
I just removed the northbridge cooler from my Asus p5W deluxe motherboard to apply AS5 and I removed the tape foam edge that around the heatsink that sits on the small capacitors and resistors on the northbridge chip package.
My question is will placing the northbridge cooler back on the chip cause a possible short when touching these smaller parts? I was considering placing PVC tape where the foam
tape used to be so these don't contact with the cooler directly.
Thanks.
Thanks.
