9700PRO Issue
Stevonio
17
Hello All =)
I have a generic 9700Pro, and lately while playing World of Warcraft at one random time the screen will go black for a few seconds, and then reappear to the desktop with an error. The error says something like "The VGA was not responding, control panel has reset it". Not sure how exact that is, but its close.
This has happend twice. I updated the drivers 2 days ago, but i forget if the error happend before or after i installed new controlpanel/drivers off ATI site.
About a month ago my fan on the card was going out, so i replaced with a vantec, removing the shin and everything. Everything has been alrighrt except for this (and another thing, but will make a seperate thread sometime).
Any idea on whats going on?
Stevo
Eureka
3,822
Hmm, try reconnecting that fan, maybe its loose. Also, just try rolling back the drivers, it shouldn't hurt.
Norm
JPB
4,064
89
I used to have a 9800 Pro that did that, But I had a underpowered psu.....I know the 9800's dont have a power connector, but it still did, replaced and it was fine. What psu do you have?
Stevonio
17
Cevilgenius - Will do :)
x80064 - Its a Raidmax 420W PSU that came with the case.
Heres where Im stumped. Whenever i replaced the fan on the video card, and booted computer everything was smooth. One day while booting up i noticed that it said "CPU Speed: 1100mhz". I know thats not right, as its an 2500XP+ That runs at 1.8ghz. So i changed the FSB back to normal. When i would open any game, i would hear a loud noise from the video card. I was told that changing the fsb of the CPU maybe have changed the fan speed of videocard or overclocked it? So i set the speed back to 1100mhz.
Thanks for your replies :)
Heres ATI's email..
Greetings!
Based on our experience, games issues are usually due to improper system configurations, driver issues, faulty hardware or a known issue with the game and the hardware or drivers that you are using.
First ensure your system meets the minimum requirements of the game and that you have any patches from the game vendor installed.
If your computer meets all of the system requirements, please check our Knowledge Base and the release notes of the driver you are using to see if there are any known issues or solutions for the game you are playing. If you are unable to find information on the specific problem you are having in our Knowledge Base, please check with the software vendor for any known issues or problems. If the problem persists, review the full details for trouble shooting game related issues at the link provided below:
http://www.ati.com/online/customercare/solutions/gamesrevised.html
If these suggestions don?t help to resolve your issues, please respond to the ticket and one of our qualified support representatives will assist you. To respond to this ticket you must visit http://support.ati.com and login to My Support.
Stevo
Stevonio
17
Hey,
Not sure how i can explain, havent heard it in awile (set fsb back so its 1100mhz). Ill try it later today and let you know.
I rolledback drivers and still got screen issue
Assimilator1
24,163
522
The FSB will have no effect on GPU fan speed ,lol ,if the FSB is set to non standard speeds on certain chipsets the AGP bus is also overclocked ,that could cause problems.
However your XP2500 (& 9700) should be fine at its default FSB
Have you actually looked to see if the fan is still turning?
