I just picked up a jetway 9600xt to fit into a Shuttle case.
The current stock cooler is LOUD.
Since the card is basically right against the side, I need a single slot solution.
Any advice out there on what can fit besides the stock cooler?
I look at the Zalman heatpipe, but the single slot model doesn't look like it's for the 9600xt.
Also, it seems like I have to give up the PCI slot if it did fit.
Hoping someone's already had to solve this
Thanks.
-- d
Thanks.
-- d
