9600 Pro vs 9600 Pro Ultra
tberger
I'm lookin at getting a new video card and I'm wondering if the ultra would be worth the extra money. I want to spend between $150 - $180.
They are all dropping right now anyways. If you were willing to spend $180, why not spend $10 more than get a 9700 128(non-pro).
He is correct-get yourself a 9700 non pro preferably from newegg.com (the sapphire) with the red pcb and samsung 2.8 ns ram (flash the bios to a retail and off you go with a 9700pro).
rogo
The 9700 will be quite a lot better than the 9600Pro or ultra or any other incarnation thereof, and will rule even more if you overclock it a bit.
If you want to overclock, the PowerColor 9600pro ??Ultra?? ($175) comes with 2.8ns Samsung ram that can make it to about 350mhz from tghe stock 300.
If you don?t plan on overclocking the Sapphire 9600pro is cheaper ($155) and comes with 3.3ns ram that really doesn?t overclock well at all.
http://www.pricewatch.com/1/37/5542-1.htm
