ok i mostly play bf42...(desert combat). and mostly when im flying i get blurred graphics. wut is that? how can i fix that....or is it just a bad card? and ill have like a glitch or two sometimes......
nobody has this problem or has ever heard of it?......by the way tooo i wanted to see if it was my 9600 so i borrowerd my friends 9500 pro and got the same thing, wut the hell is going on?
Check the settings in your ATI utility (display settings, settings tab, advanced, Direct3D). I typically keep everything below AA and AF on or high except truform, and AA and AF can be used at your discretion. Just a poke in the dark here.
