960 Evo Temps??
TahoeDust
557
404
For storage on my rig I am running two 500GB Samsung 960 EVO M.2 drives in Raid 0 and I also a 1TB 850 EVO SSD. Tonight I was moving some game files from my M.2 Raid array to my SSD. It was about 400GBs total. I happened to have HWInfo64 open monitoring something else when I noticed two M.2 drives temps go red...they were breaking 80c...
They both maxed out at 84c but seemed to hover i the mid/high 70c during the move. My questions are:
1. Is this safe?
2. Is this normal?
3. What is the difference in the two temperature sensors on the 960 EVOs?
4. Do the heatsinks EK sells actually work?
Elixer
10,371
762
Most all of these type of devices run hot.
Heatsinks might help more than none, however, direct airflow seems to help the most.
Campy
785
171
The controller heats up during sustained data transfer, it's normal from what I've heard. For that reason I'm going to guess the #2 sensor is for the controller. It's safe because the drive will throttle to protect itself, giving you less performance until temps come down. Like Elixer said, some heatsinks and/or airflow should help
BonzaiDuck
16,639
2,029
Perhaps devote some tedium, time and attention to case airflow plus installation of something like this?
