When there is cold weather here, and there is plenty here in Alaska, my wife's Saturn ceased to start.
If I take off the intake tubing (not a car guru here, not very technical terminology) and bring it inside, after it thaws I can dump a smallish amount of water out of it.
I believe this is the cause for the problem, and a mechanic told me that it takes in cold outside air instead of air off of a warm part of the engine and this leads to the condensation. If this is true, then I am not sure if there is even anything I can fix.
Strange problem for sure, maybe somebody has some insight here.
~130k miles
Multiple things have been replaced, including spark plugs most recently and O2 sensor, fuel pressure regulator ( I think, dont remember the exact name, it has to do with the same issues as the O2 sensor) and finally a new cat convertor within a few thousand miles.
My only thought is perhaps trying something different with the whole air intake/filter system, but I have no clue where to begin.
Thanks for any help.
~130k miles
