9500PRO and memory questions...
nygkrangers
Ok, this is the card I want, right?
http://www.pcrapids.com/home.asp?pw=y&pwl=search/productdesc.asp?lsskuid=VidATI128M01395
And, I'm thinking about the SimpleTech PC2700 that Newegg is selling for $59 for a 512 stick. I don't plan any major overclocking. I'll be using the Gigabyte 8SQ800. I'll get 2 sticks of the same RAM for the dual channel capabilities.
So, would these be good choices? Any complaints about the memory?
The 9500PRO from PCRapids seems fairly cheap, so I just wanted to get your approval on that. Thanks.
I would get some Kingston HyperX2700 memory or HyperX3000 from newegg. If you wanna stick with PC2700, get the samsung originals from Newegg. The Video card looks good and you're good to go.
