Since most of the users on AT are very computer-proficient, I figured I'll try this. Maybe some of us are also proficient in Japanese computers with 4 wheels.
<FONT class=nf face=Verdana>Hello everybody,
The ABS light on my baby came up. I have been trying to locate the diagnostic connector to check ABS codes but so far have been unsuccessful.
I found a white 2-pin connector behind the center console on the driver's side. I tried to short it to read codes, but only the SRS light flashed.
There are two blue connectors (a 2-wire and a 3-wire ones) next to the white one. However, they are plugged into something.
Which one of this will flash ABS fault codes when shorted? Do I need to unplug a blue connectore from whatever it is plugged into and then short it?
Please help me before the airbag blows into my face and/or the dealer charges me an arm and a leg to diagnose and fix the problem.
Thanks.</FONT>
Thanks.</FONT>
