940BE temperature not showing up.
The Sly Syl
277
I wish i could remember exactly when this problem started, but i can't recall. When i realized that my temperatures were all within safe limits, i stopped monitoring them 24/7. At some point my temps started reading as 0'c for most programs (Core temp, speedfan, AMD overdrive, hardware monitor, etc.) and -256'c for others.
I know that my temps are safe (generally under 40'c!) with my Xigmatek Dark Knight, but I really want to know if there is anything i can possibly do to make it so that all 4 cores don't show up as 0'c.
I'm running a Foxconn A7DA-S with the most recent updates according to the Fox liveupdate utility.
Every single other temp sensor seems to be running normally and reporting normally. It's purely the CPU Core # that show up as 0'c
The Sly Syl
277
Would that continue even if i haven't used it in a long time? ACC shows -256c per core.
Without it on, everything else shows 0'c. I used ACC to get up to a stable 3.6ghz and then, after realizing that the heat and the power both were not necessary, i went down to stock and turned on C&Q. I'm sure in the future i may enjoy that 3.6, but i don't really find it necessary right now. I think i was running about 31c non overclocked if i recall correctly, 45c load.
deimos3428
697
I think there's some confusion here, let me try to fix.
AOD = AMD OverDrive. The application where you're seeing temperature readings of -256C, a tool used for monitoring/overclocking
ACC = Advanced Clock Calibration, an option in the BIOS. Turn it off and the temps will likely come back. It's used mainly for unlocking cores, pointless on an X4.
The Sly Syl
277
oops, yeah, i was thinking the AMD overdrive.
I don't think i have ACC on, if i do, somehow, have it turned on - it must be by using a different name. As i said, i'm currently running everything stock, so i disabled all overclocking measures.
The Sly Syl
277
Originally posted by: deputc26
You have a bad temp sensor then, RMA.
would RMA even be possible on a black edition chip after i've overclocked it and used an aftermarket heatsink and thermal paste, not to mention used it for roughly 4 months?
I'm pretty sure i destroyed the warranty on this thing.
reallyscrued
2,618
....I really, really, really doubt its a bad temp sensor.
You have ACC enabled for sure. Its a BIOS setting. It's probably set to hybid/auto, set it to normal or disabled.
Also, try Everest, its known to provide temperatures even when ACC is enabled.
Edit: I don't think any manufacturer uses a different term for ACC. Look for something with a table of values, usually -2, much like this:
http://www.overclock.net/galle...ium/CPU_ACC_and_NB.JPG
