birthdaymonkey
I just got a Phenom II X4 940BE to replace an X2 555 (that wouldn't unlock). I'm using a Gigabyte GA-MA785 GM. My case is a Lian Li PC-V351, and I'm using a Scythe Big Shuriken cooler (limited clearance in this case requires a lower profile HSF). The case is well ventilated (stock case fans replaced with higher performance ones).
The new chip is running extremely hot. With the 555 my temps maxed out at 49C under Prime 95 for 6+ hours at 3.83GHz OC. The 940 hits 70C, which is way above the max safe limit of the chip. This is at stock clock, 1.375 volts.
Of course the Big Shuriken doesn't cool as well as a tower HSF, but I've read of people using it with hex core Phenoms and i7 920 systems and they don't seem to have the extreme temps I'm experiencing.
I think the problem might be the thermal compound I'm using, which is a tube of generic stuff that my brother in law gave me (not sure of its origin). Since I got the CPU for Christmas, I don't have the immediate option of buying new TIM (everything is closed today), but I'm wondering if the cheap stuff could really be that bad?
