930B Digial problems
Nickma
Hello all,
Just bought the 930B and got a DVI cable. When I have the DVI cable plugged in I get nothing and when I plug in the standard VGA it works fine. I was pressing the button between analog and digial modes with no success. Is there something else I have to do or do I have a bum DVI cable?
Thanks for your help.
By default the monitor should search for the source. You should see a graphic in the upper left of the screen swiching between Analog and Digital until it locks on. If not check the monitor Setup to make sure "Auto Source" is set to Auto.
BTW, I am using a 930B with the included DVI cable right now. The cable is plugged into the DVI-I port on my video card.
