alphatarget1
- Dec 9, 2001
- 5,710
- 0
- 76
If it's worth the extra $0.40 / gal to make your car feel like it gained 10hp, then sure.
100 octane on a chipped 335i, on the other hand is :thumbsup:
There is so much fail in this thread it hurts.
91 or 93 + can of autozone octane boost and K&N = stop light monster, do it your car will own.
True dat, here's a camaro with a K&N
http://www.youtube.com/watch?v=3gg3wxS1LeU
i dont even know where the manual is. been putting 87 for a year. only a 25 cent diff between 87 and 93. 87 makes it run like crap. no wait, maybe its the 1.8L engine that does that.
Why does it need premium? Just because the compression ratio is 11:1? With aluminum heads and block it is more likely than not that it will run perfectly fine on 87. Aluminum carries heat away from the combustion chamber so fast that old rules on compression ratios and octane requirements are not valid. You actually have to raise the compression on all aluminum engines just to get back the power loss from not using cast iron.
If you run a higher octane that required you can actually LOOSE power and mileage since the fuel is harder to burn and thus you may not get complete combustion. I have verified this on a dyno more than once to non believers.
^_^ Let me get that for you... > Click Here <
if that's legit, then thanks. ill try 89 and see how it performs
Wait, I thought you were the biggest Honda fanboi snob ever...
Probably because there is more actual fuel and less crappy stuff so (I think) you actually need less fuel. It's not that 93 is 'harder to burn' it's that there is more useful fuel in it, so you wind up running a little rich if you just switch from 87 to 93. I notice changing fuel grades, 91 vs 93, in the fuel trims in my MS3, it will adjust its fuel trims because it does closed-loop fuel correction with a wide-band O2. I definitely get better mileage on 93 vs 91 because of this, verified over 2,000 miles of driving cross-country.
Stop posting.
Nah, the people who make the honda website are just stupid buggers.I thought SI's wanted premium?
Usually it's the other way around. Molecules with higher octane ratings tend to be lower energy density. Ethanol and propane are very low energy density, very high octane rating. Diesel is very high energy density but very low octane rating. Cyclohexane and benzene are a good comparison; while both are very similar molecules, the benzene is more stable, benzene releases less energy when it burns, and benzene has a higher octane rating.Probably because there is more actual fuel and less crappy stuff so (I think) you actually need less fuel. It's not that 93 is 'harder to burn' it's that there is more useful fuel in it
Why post that rather than simple doing a Google search?I've heard the octane on rocket fuel is so high it won't even light with a match. That may be bullsh*t, though
Yeah, probably is!
If you put a little bit of diesel in your gasoline, the gas engine will knock like a bitch. It dramatically lowers the octane rating of the fuel.Diesel has a very high octane rating, not low. But yeah it has nothing to do with energy content
Wow. An econo-box engine that needs premium? Another fail point for the Si...
The Si specs look pretty good, if the car was from the 80's.![]()
