92mm white LED fans?
Synomenon
Anyone know where in the USA I can order 92mm white LED fans? I need them for a Noctua NH-U9B SE2. The included fans are great, but the brown color doesn't go with the theme of the case it's going in. If the case didn't have a window it would be fine, but it has a big window.
Thermaltake used to offer such a 92x25mm fan, although I think it was more blue than white. It just seemed to me it had an element of whiteness. Does it posi-lutely abso-tively have to be white?
Those fans weren't as noisy as you'd suspect from a purveyor of gaudy glitz like Tt. They were very controllable, had some extra features, maybe even an option thermal sensor wire. Without the sensor, you could run them at top end, or control them by the various traditional means. I thought the amperage was somewhere around 0.28A. Can't remember the spec output in CFM, but I always chose fans for their high-CFM potential so I had more to work with on my end.
I just don't know if anyone sells them anymore. For all I know, I might have one new in the retail box, buried in my parts locker.
