92mm fan + xp90??
johnnqq
i was looking at a panaflo l1a fan for an xp 90...but its not on newegg. i went to thermalright.com and couldn't find nf4 ultra compatibility with the xp 90...so it doesnt work with n4f mobos?
and is a 7700 too big for a sonata 2 case?
I'm pretty sure that on the Thermalright website, it says that the cooler will fit on any 754/939/940 MoBo, (although ppl with gigabyte MoBo's need to use a special retention bracket).
RoD
if this isnt already a closed thread:
just bought two XP90s...the XP90-c is too heavy (approv 250G over recommended) and the 120s...too big and dont fit my mobos.
Against the Zalmans: they require to to pull your mobo out, put a new retention bracket in, and be ever so careful to not overtighten the mounting screws....I think I wont touch that.
XP90 - can use AMD mouting bracket (unless it is a gigabyte) and it is very light. (300 some grams + weight of a 92mm fan)
get the zalman 92mm fan, it moves up to 53 cfm and owns the panaflo, i speak from experience with no ac in my room and 95 degree weather here in chicago.
if thats not an option get the thermal take silent cat 92 mm fan(white one), trust me youll thank me later
The XP-90 fits just about every A64 board made; you don?t have to worry about compatibly.
As far as fans go I wouldn?t buy any fan from Newegg, they are far too overpriced. Also stay clear of ThermalTake fans their specs are so far of they are completely meaningless. Sidewinder Computers has a nice selection of fans, including the Panaflo/NMB L1A.
A Zalman 7000/7700 would also be a good choice, you'll have to make sure you can fit the 7700 though.
XP90s don't work on Gigabytes?
I refuse to use any Zalman cooling solutions. There are a number of reasons:
1.) they weight way to much! The 7700 CU is 850 some grams, and the max weight limit for both A64 boards and P4 board is.....(drumroll) 450g! This can cause serious problems when you move sour computer. (think 850g hanging off the PCB of your mobo, wouldn't you be worried that you'd move it the wrong way, and break a few of the very delicate traces?)
2.) you have to change your mounting backplate on the A64 boards. Ummm, I don't know about you, but I don't feel like pulling my PCI/AGP cards our, ram, etc, removing the mobo, getting the backplate off (which is glued on) and putting a new one it....Zalman is a bunch of idiots for not making it easier for A64 people.
3.) cost. First, the Zalman 7700CU is $40-$50...my XP90- $35+$1 for a fan. Second: the XP-90 has a fer easy system for switching fans. I can just pop off one, put in another. Done. The Zalman? ohhh, no, you gotta get their specially made fan....and that is BS! I don't care how good their fan is, I don't want to have to jump through hoops just to get a new one!
4.) cooling advatage of the 7700 over the XP90 (or XP120) is VERY minmal. Not enough to compensate for the price difference. Mind you, the XP-120 is huge, and can't fit some mobos, but the XP-90 is even just as good.
