92mm enermax fan?
johneetrash
3,791
hows it being held on to the powersupply? looking into the power supply it doesnt look like the screws are holding on to it... i wanted to take out the grill so i can make sure all the holes i have measured for my 92mm case fan are right. thanks :)
Jhhnn
IN MEMORIAM
Nov 11, 1999
62,365
14,685
The same screws that hold the grille hold the fan to the housing- like a sandwich. Just measure center to center on the screws, you don't have to take it apart. Putting it back together is a little tougher.
