9000 pro problems
coinopbot
12
hello,
My bro just picked up a Powercolor Radeon 9000 pro, and after he installed the drivers, all of his windows icons turned black, like it only showed the icon masks or something.
Has anyone heard of this problem? or knows how to fix it?
- 25cents -
DougB
When I have had icon problems (due to many causes, most of which were unknown), what often has fixed them is to delet the file "shelliconcache", which is located in the Windows directory, then restart windows. Windows will then rebuild the file. Give it a shot. BTW, this file is hidden.
Doug
coinopbot
12
Nope, didn't work.
He is running Win98, and the icons are all black.....
i erased the shelliconcache and restarted..... but still the black icons remain.
They have been there since he has installed the card.
- 25cents -
jiffylube1024
7,430
Originally posted by: klah
Have you tried using the latest ATI reference drivers?
Yeah try either the latest ATI drivers, or the last WHQL certified ATI drivers that support the 9000 pro.
BFG10K
22,070
1,241
Did you correctly remove all traces of your previous video card before you installed your 9000 Pro?
ASK THE COMMUNITY
