8RDA+ Problems:
Arhra
75
Just finished building a new system, but I ran into a problem. All of my fans spin, I get power to my devices, but I'm getting a "02" or "20" reading on the 8RDA+'s LED to indicate what went wrong in the BIOS. Both of those say "reserved" in the manual. The beep code is long-short. I couldn't get any type of answer on Epox's site or in the manual. Any ideas?
Thanks guys.
LED
6,127
Don't have that MoBo but prolly the Memory...check ober @ the Motherboard Forum and you'll most likely get a confirmation.
bjc112
11,460
I'm getting that MOBO and im ALMOST positive the 02/20 is memory not seated properly...
Reseat!
:D
Arhra
75
Ok, I reseated the memory in both channels, a no go with Kingston HyperX PC3200. I then put in a Kingston PC2100 module and the system posted. Any ideas?
EDIT: By trying "both channels" I mean putting 1 DIMM in slot #3 and when that didn't work putting it in slot #1.
