8RDA+ HDD LED Stay on
lchen66666
359
Just realized my 8RDA+ HDD LED keep stay on, never turn on.
Also found recently the motherboard doesn't go to Energy Save Mode if I don't used it for while, and
I checked the BIOS, everthing is set correctly.
Anyone had same problem before ? Know why ?
Thanks
KF
1,371
I don't know about the HD LED. There does not seem to be any way that it could be on constantly unless the HD is constantly accessed. I would check that the light is on the right mobo pins. Or maybe you have a program constantly running in the background, such as a virus scanner.
Power saving modes are controlled within Windows. I believe Windows over-rides what is set in the BIOS, although I have never attempted to see if it would work the other way and the BIOS would over-ride Windows settings. There is a Power Options applet in Control Panel to set what you prefer.
