I have a ABIT AN52 Socket AM2 NVIDIA nForce 520 MCP ATX and a Thermaltake TR2 W0070RUC ATX 430W Power Supply the problem is the motherboard has a 8 pin cpu power connection but the psu only has a 4 pin cpu connection. Now ive read on some sites that you can get away with just using the 4 pin connection but im not sure if i should put it on the left side or right side or even the middle.
Also the motherboard is a 24 pin power connection but the psu has a 20 pin with a extra 4 pin connection some people said just take the 4 pin from that and use it for cpu to fill in but i dont think that will work with the mb only getting 20 pin instead of 24
