gujuguy007
Just installed my 8K7A and everything was fine but then i started getting lockup problems when i tried installing drivers for my sound card and my video card. Windows98 would stay at configuring pc for more than 10 minutes. Eventually i gave up and restarted the computer. This happened like 6 times and eventually i gave up. The drivers installed successfully but i still get the same problems when installing other stuff. Can anybody tell me what would solve this. Which drivers should i download for the mobo and which drivers should i not download? I know there is a AGP driver bad somewhere but cant remember. Can you please link it too. Also an FF code shows even when I am in windows98 on my mobo. Is that normal? I mean everything else seems to be running fine. My temp is 42 degrees C and stable. Also how do i disable the onboard sound? Sorry but i am a newbie. My specs are below just in case.
Enlight 7237 ATX 300 Watts
Gigabyte Geforce 2 MX 32MB SDRAM w/TV out 4X AGP
IBM 40 GB 7200RPM Deskstar 60GXP Ultra ATA/100
Toshiba DVD ROM, 16X DVD, 48X CD ROM
Linksys Ethernet Card 10/100
Creative Lab Soundblaster Live! 5.1 sound card
Retail AMD Athlon Thunderbird 1.33ghz/266 FSB w/HSF
Samsung DDRAM 128MB 16X64 PC-2100 (2)
thanks if anybody can help again
