Question 8K Graphic card with
hektor314
Hi
I need help of this community
I want to buy cheap or up to 500 - 600 pounds gpu which supports 8k.
I recently bought taichi x570 pcie 4.0
Dont know anything about GPUs and wanted to ask you what would be the best buy for 8k at 60hz preferably and pcie 4.0 if possible.
If not is pcie 3.0 GPU compatible with my pcie 4.0 motherboard?
I am not goona be gaming. This is for productivity and mutltasking.
I have 3 4k monitors. Need just I suppose GPU to do (Dynamic Super Resolution ) NVIDIA or Radeon VSR
Do I need to worry about hdmi 2.1 and 1.4a?
GOD... there are so many choices that Im lost.
Thanks for sharing your thoughts.
Are you replacing the three 4K displays with a single 8K, or will you be using all of them together? That can really change our suggestions.
I am gonna be using them together. Just need to 8key them maybe 2 of them not 3.
Thanks for the answers.
Is DSR Digital Super Resoluiton any better than VSR?
woah, 2x 8k monitors? I am feeling a bit jealous.
You might end up needing more then one graphics card. That is 5 monitors your looking for now, right?
The Radeon Pro W5500 has 4 DisplayPort 1.4 outputs. It's validated to output to 4, 4K monitors at 60Hz, or 2, 8K monitors at 60Hz. It also supports H.264 and HEVC Decode at 8K resolutions.
