Page 122 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
poke01
4,522
5,830
They have an 8GB card listed for 1440 high, what gives?
GcM7s_wWEAErrYS
Yeah I don’t believe that for a second lol. The RTX 4070 and RX 6800 XT have 12GB/16GB respectively.
The 3070Ti is both slower than both these cards and has less VRAM. Most people should take these specs cards as a guide I suppose, not as gospel.
19,203
^^^ What a shill Nvidia being, using the 14900K in their test bench, just coz they would like AMD to not exist.
The same 14900K that caused crashes and out of video memory errors on THEIR cards used by THEIR customers.
Seriously, WITAF :mad:
Reactions: Tlh97 and marees
poke01
4,522
5,830
More than likely these were done in early November before the 9800X3D was available. Now the 5000 series better be on AMD.
AMD also tests their CPUs using the RX 7900XTX instead of the 4090. They did it for the 9800X3D leaving fps on the table. It’s best to ignore these first party tests.
19,203
AMD can be excused because they have their own CPU and it's currently the best for gaming on average. But Nvidia testing that game with 14900K shows how evil they are. They are doing free marketing for a CPU with WELL KNOWN degradation issues and the harm they will cause to their gullible users in the long term by doing that is going to be epic if even 20% of their users are impacted.
This is Nvidia we are talking about. It's not like some techie in a basement did those benchmarks and released them. God knows how many people were involved in signing off on those benchmarks. That not one of them objected to 14900K says a lot about their culture. This is nothing but corporate politics. The worst kind.
Taltaus
Cool, so stalker 2 will run with my 4070 in 2k. Great! Though have to upgrade to 16 GB ...
Edit: well - nothing is running in the end lol - i have a really great with ryzen 9 and rtx 4070 (the msi version mentioned in this article) and i cant get stable 50 fps in 2k - what a joke ... sometimes the fps drop to 15-20 ... often when i enter a small town :/
poke01
4,522
5,830
I agree with that not great optics. Even a 7800X3D would have been enough now that I think about it
marees
1,981
2,611
I think if intel bug is fixed, then it could actually be better during shader compilation & texture uncompression especially for low vram nvidia cards
Ranulf
2,884
2,544
not surprising, you need minimum 12GB for this game.
Love games like these, cause they actually put your cpu/gpu to work
It is certainly looking like a game that will need some more time in the oven for patches. Some people it runs well but for many it appears to be rather buggy.
Reactions: poke01
poke01
4,522
5,830
CPU used is 9800X3D
I'm really impressed with the 4070 Super here, it beats the 7800xt at 1080p and 1440p while pulling less watts but at 4K the higher vram and higher bandwidth gives way to the 7800 XT for 10 more frames.
Shmee
8,268
3,154
Yeah the mid tier Geforce cards are a bit of an odd place in terms of performance per $. The 4070 Super has similar performance to a 7800XT, but costs more, and has less memory than it or the 7900GRE. Though it generally has better RT performance, I am not really into that, so I think the 7900GRE is a better choice in that price range. Also, to my understanding the 7900GRE can now have it's memory easily OCed for more performance, due to being similar memory used in the 7900XT or XTX, but being clocked lower in the firmware.
DAPUNISHER
32,136
32,711
Tim revisited the RTX 2060, and one of the big problems is 6GB.
In 4yrs we will probably be viewing the current expensive 12GB cards the same way. I.E. Overpriced, poor choice for current RT, not enough vram, and forced to use more aggressive upscaling. Frame generation is also turning into an important feature due to how badly games are optimized. If you want high refresh fps anyways. It needs vram the same as RT, and I would rather have 16GB or more. If I was shopping I'd buy the 7900XT, the extra $50 is money well spent IMO.
DAPUNISHER
32,136
32,711
TPU's street cred is going right in the toilet. He used the 9800X3D for some of the test but still has the 14900K in use = GTFO. Then the conclusion is contrary to everything else I've seen from testing in the game's current state. Undoubtedly due to such short test runs. I watched Pedro play on a 4060 and it will flatout stop for 1/2 second at times. While AB does not show the vram being exceeded the system ram spikes up when it happens.
VRAM
Our testing shows that Stalker 2 is very well-behaved in terms of VRAM usage. Even at 4K you're barely hitting 10 GB; lowest settings runs at around 6 GB, so virtually all cards can handle the game without problems. Interestingly, some AMD cards with 8 GB VRAM take a pretty big performance hit at 4K, while their NVIDIA counterparts are not affected. This is probably due to the GPU architectures managing their memory differently. Enabling frame generation on top adds another 1-2 GB, not a problem at all.
poke01
4,522
5,830
Same story with RTX 5000 non-supers. They will be more expensive and will knee-cap on VRAM.
So Nvidia won't have a good midrange lineup till early 2026... Best to vote with your wallet and go with AMD next generation and Intel if BMG is good for midrange.
poke01
4,522
5,830
Ok it looks like the 5070 Ti will not have 12GB VRAM like the 4070 Ti did at launch and it will have a 16GB and 256-bit bus width. With GDDR7 also, its the card to get for the 5000 series.
Its best to avoid the 5070 as that will have 12GB VRAM.
With this new information its bit better but the rumours of the 5070 Super have 18GB is much more enticing than this but until then 5070 Ti would suffice Nvidia buyers. AMD and Intel have a great opportunity to take the $300-400 market now.
Reactions: Elfear
Thunder 57
4,147
6,920
If those specs are accurate only the 5070 Tye makes sense. The 5070 and below will be handicapped by VRAM. The 4080 will probably only be a moderate lift and cost more. The 5090 will sell I'm sure no matter what the price but if that power is true it will be a small spaceheater.
Status
