Page 118 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Status
Not open for further replies.
BFG10K
22,709
3,005
This thread was started in mid 2021 and is being retired/locked. As the OP is no longer active, or updating and maintaining it.
Mod DAPUNISHER
8GB
10GB / 12GB
  1. It's the player's fault.
  2. It's the reviewer's fault.
  4. It's AMD's fault.
  5. It's the game's fault.
  6. It's the driver's fault.
  9. Wrong area was tested.
  10. Wrong games were tested.
  11. 4K is irrelevant.
  16. It's an anomaly.
  17. It's a console port.
psolord
2,142
1,265
Bigger bar better fails again? 25 second test loop to blame? How else does a 4060ti having run out of framebuffer have the same min FPS as its 16GB bro? DRS bug? Textures not loading and/or popping in, or horrible frame times should be the result, yes? Chart can't show the potential visual issues either.
https://www.techpowerup.com/review/god-of-war-ragnarok-fps-performance-benchmark/5.html
This one does not have a VRAM problem either.
Here is my 3060ti, 40 minute run. I made this one challenging. It is at 4k DLSS Balanced, essentially 1248p, but at ULTRA preset,. Still higher than 1080p and certainly quite higher than what the 3060ti would be used for. No pop up, no textures missing and that on a 11yo cpu. No it's not perfect. It has many framedrops. This is just a proof of concept run.
Also if you want to know.
RX6600, 1080p Ultra, FSR3 quality, same run, perfect 60fps. No vram problems either, gpu power limited as well. It cannot do what the 3060ti can do, despite the same framebuffer.
RTX 4070ti, 4k, Ultra, DLAA, pretty close to 60fps, has some framedrops.
GTX 1070, I don't know, because the devs decided the game needs FMA,AVX2 and F16C capable cpu and my 2700k does not. GTFO.
Also if you want to know and are an old hardware lover like myself, the game did run on a GTX 970, even if it needed a mod at the time. It's not great, but if the GTX 970 can run it at ~30fps, I bet 8GB cards will be fine.
More on that from gamegpu. 3060 is tanking again. VRAM aint helping.
Screenshot 2024-09-25 at 13-27-26 God of War Ragnarök Patch 2 - PC performance graphics benchm...png
Ranulf
2,882
2,543
Huh, so a 2070 is equal to a 4060 but one has no FG, well nvidia version. Pretty crazy specs though. Glad I never got into the MH games.
DAPUNISHER
32,121
32,695
60fps using frame gen will be laggy as hell. Wait for gameplay to see what's up, as always.
Reactions: WelshBloke
SolidQ
1,524
2,501
most gamers don't know what it really does
most gamers didn't know about pc setting, they just press start game and play.
FSR FG?
Could be it that the game developers don't really understand FG
looking how they achieve very high quality graphic in PS4 era, and now. Seems they don't know where to move
Maybe that because PS4 have GCN arch, which game + compute, RDNA pure gaming. So PS6 with UDNA should bring big boost
Mopetar
8,507
7,762
Ummm....I was referring to the Age of Mythology RT results. CPU has nothing to do with it here. According to your logic, this is a proper result that we should pay attention to, since it's "maxed out" settings right?
I missed that this is a modern remake and had assumed it was the original from decades ago. It still doesn't make your point. It just shows that the used something specific to NVidia that runs poorly on AMD cards. Trying to conflate that with arguments about VRAM is not only wrong, it's dishonest as hell and frankly anyone with a clue should have been able to tell that just from looking at the chart you've posted.
Even worse for you it also disproves the point you thought you were trying to make. The 3080 is 35% better in that chart than the 3070 Ti. Using TPUs results (https://www.techpowerup.com/review/nvidia-geforce-rtx-3070-ti-founders-edition/28.html) for their suite of games, a 3080 is on average 11% better than a 3070 Ti. The only way we should see a number like 35% is if the 8 GB VRAM in the 3070 Ti is bottlenecking the card's performance and the extra 2 GB that the 3080 had doesn't hold that card back.
Or to put it another way, the 3070 Ti is losing 11 FPS based on TPUs relative performance charts because it only has 8 GB VRAM. Whoops. I hope no one spent $600 on a card leaving so much performance on the table.
jpiniero
16,948
7,369
At stock, the 3080 has 37% more compute and fill rate and 25% more memory bandwidth though. Performance wise it should be a lot closer to 35% than 11%.
Golgatha
12,408
1,087
Not really a VRAM issue, but more of a monopoly one, is that my laptop with a 2070 8GB mobile plays pretty much the same games at the same settings as anything nVidia has in the mobile space that's attached to 8GB of VRAM currently. I absolutely hate that one has to spend $2k+ in the mobile space to get a gaming laptop that has any amount of longevity to it.
Mopetar
8,507
7,762
The 11% comes from TPUs actual testing results across their 22 game teat suite in 1080p. The 3080 widens performance at 1440p and 4K resolution, but the bigger GPUs have never scaled actual performance with their theoretical uplift based on paper specs. It's just Amdahl's law at work and everyone has known that you see diminishing returns the further you move up the stack.
For instance, in the same chart the 3060 gets 69% of the performance of the 3070 Ti, yet it only has 58% of the shaders, 83% of the base clock speed, and 59% of the memory bandwidth. In other words the 3070 Ti loses about 17% of its theoretical performance edge over the 3060 in the real world. Though that card does have 12 GB of VRAM so if there are games in the test suite where 8 GB bottlenecks performance, it would let the 3060 punch above its weight compared to the 3070 Ti.
marees
1,973
2,605
This needs stressing again & again:
If you intend to play PS5 exclusive games such as Ratchet & Clank or Spiderman then either buy a PS5/PS5 pro or buy a card with more VRAM
Ratchet & Clank...​
This title is one of those where the developers have easily observable optimisations which work specifically on the console hardware. The PS5 Performance mode achieves a locked 60 fps on the console but, here, we're VRAM limited* on the RX 6650 XT. This is multiplied multi-fold when switching to 4K resolution... and the 16 GB framebuffer of the RX 7600 XT handles both situations with ease.
ToTTenTranz
795
1,288
Ratchet & Clank...​
I don't know who the author is, but the PS5 usually renders at 1440p and the RX 6700 has 2.5 times the amount of Infinity Cache (at 2.5x the bandwidth per clock) over the RX 6650XT which definitely makes a big difference at that base resolution.
They assumed those cards were similar from the 1080p results, but they're probably not that similar at 1440p and up.
psolord
2,142
1,265
How to spot slanted presentation in one easy step:
  • RX6600: "perfect 60fps"
  • 3060: "is tanking again"
The cards:
You all are seriously biased against everything I say in this thread, oh my god.
I was referring to what I found out from my own testing and I am clearly saying FSR3 quality up there. You took the results I posted without FSR3.
This is the aforementioned rx6600 run
And yes, this falls under what I call "correct settings".
psolord
2,142
1,265
This was not meant to be Nvidia vs AMD, rather VRAM vs GPU power, with accordance to what you requested, meaning the games being tested at max, no matter what.
In my book that was a stupid example, as are many of the examples people are looking here.
Oh but it does prove my point exactly. The 3080 has 68 RT cores while the 3070ti only has 48 RT cores. That's a 42% difference and will most likely pop up its ugly head, once heavy RT is used
psolord
2,142
1,265
I bet he would've good things to say about 3060 12GB IF he owned it :)
I wouldn't own it though, as I already don't, because I don't belong to the ignoramuses that see 12GB on the box and get impressed!
Here is some more future proofing of the 3060, from latest tests of gamegpu.....
Greedfall II
Enotria
Forever Winter
Starfield Shattered Space
Throne and Liberty
Screenshot 2024-10-02 at 15-10-11 Throne and Liberty - PC performance graphics benchmarks of G...pngScreenshot 2024-10-02 at 15-10-40 Starfield Shattered Space - PC performance graphics benchmar...pngScreenshot 2024-10-02 at 15-11-10 The Forever Winter - PC performance graphics benchmarks of G...pngScreenshot 2024-10-02 at 15-11-45 Enotria The Last Song - PC performance graphics benchmarks o...pngScreenshot 2024-10-02 at 15-12-16 GreedFall II The Dying World - PC performance graphics bench...png
Everything unplayable, without the mandatory applying of correct settings!
Status
