880G Chipset/4250HD - Work with 2560x1440?
Brother Ali
127
Hello, I was hoping one of you guys could help this n00b?
I have this motherboard:
http://www.asrock.com/MB/AMD/880G Pro3/index.asp
Specs:
- Supports HDMI Technology with max. resolution up to 1920x1200 (1080P)
- Supports Dual-link DVI with max. resolution up to 2560x1600 @ 75Hz
- Supports D-Sub with max. resolution up to 2048x1536 @ 85Hz
I want to buy a monitor that runs at 2560x1440 but it has HDMI, display port and VGA.
https://www.amazon.com/HP-Pavilion-32-inch-Wide-Viewing-Display/dp/B01FGCJBGK
My motherboard doesnt have a display port so my only option would be HDMI/VGA (no thanks). HDMI seems to only go upto 1080P.
Azuma Hazuki
1,532
866
131
Unfortunately it doesn't look like it. Even an HDMI to DVI-D adapter wouldn't help since the source signal goes no higher than 1080P.
Invest in a GeForce GT1030 maybe? IIRC those can do it and they're cheap and cool.
