- Nov 21, 2007
- 52
- 0
- 0
I have been having a issue with my 8800GTS G92 since about four weeks. The graphics card is being downclocked as per rivatuner info here:
$ffffffffff ----------------------------------------------------------------
$ffffffffff Display adapter information
$0000000000 Description : NVIDIA GeForce 8800 GTS 512
$0000000001 Vendor ID : 10de (NVIDIA)
$0000000002 Device ID : 0600
$0000000003 Location : bus 1, device 0, function 0
$0000000004 Bus type : PCIE
$000000000f PCIE link width : 16x supported, 16x selected
$ffffffffff NVIDIA specific display adapter information
$0100000000 Graphics core : G92 revision A2 (128sp)
$0100000001 Hardwired ID : 0600 (ROM strapped to 0600)
$0100000002 Memory bus : 256-bit
$0100000003 Memory type : DDR3 (RAM configuration 00)
$0100000004 Memory amount : 524288KB
$0100000100 Core clock domain 0 : 399.600MHz
$0100000101 Core clock domain 1 : 810.000MHz
$0100000006 Memory clock : 499.500MHz (999.000MHz effective)
$0100000007 Reference clock : 27.000MHz
$ffffffffff NVIDIA VGA BIOS information
$1100000000 Title : GeForce 8800 GTS 512 VGA BIOS
$1100000002 Version : 62.92.25.00.02
$1100000100 BIT version : 1.00
$1100000210 Core clock domain 0 : 400MHz
$1100000211 Core clock domain 1 : 800MHz
$1100000201 Memory clock : 500MHz
$1100010003 Performance level 3 : 670MHz/1674MHz/972MHz
$1100020000 VID bitmask : 00000011b
$1100020100 Voltage level 0 : 1.00V, VID 00000000b
$1100020101 Voltage level 1 : 1.05V, VID 00000001b
$1100020102 Voltage level 2 : 1.10V, VID 00000010b
$1100020103 Voltage level 3 : 1.15V, VID 00000011b
$1100030001 Core thermal compensation : 8°C
$1100030002 Core thermal threshold : 100°C
$1100030006 Thermal diode inaccuracy : 0000b
I bought it in late Dec, and it has been working fine till a few weeks ago. One day, I suddenly noticed that the card was showing up zero clocks on RivaTuner(in the overclock dialog, 'detect now' shows 0, GPUZ, ntune, Nvidia ESA software etc.. I hadn't changed anything in the past few days at all, installed no drivers or didn't change any settings. (I had installed Vista SP1 like 3 weeks before this started happening, so can't blame it). It doesn't upclock itself under load either.
GPUZ, ntune and RivaTuner show the clocks as zero, but from later on, RivaTuner started showing the real clocks(the underclocked ones). I changed driver versions in Vista(didn't reboot), and it returned to stock speeds, but after a bit returned to the lower clocks. I immediately downclocked my Q6600 back to stock speeds in the BIOS but there was no effect. I heard about the x4 PCI-E slowdown so I always checked the PCI-E lanes and GPUZ and other apps show it's running at x16. Also, I've never set any tools like RivaTuner to run on startup ever. I used to overclock, play and downclock to stock and sleep. One day I left the fan running at 75% by mistake and set it back to stock the next day but can't see that causing any problem.
I installed and reinstalled almost all the possible driver versions(including the latest 174.74), used driver cleaner to clean them in safe mode, changed and updated the nforce mobo drivers. I heard about the power supply bug with the G92 GTS and disabled the system sentinel services on startup and tried the 169.44 in which this bug was fixed, but with no success. I also updated my GPU BIOS to the latest version from EVGA but the problem persists. UT3 performance is down a lot, and 3DMark06 dropped from close to 12K to 7K
Even UT2004 shows some slowness even while showing 75fps as the framerate(vsync on).
Very rarely, I see the normal speeds after cleaning the drivers and reinstalling, but they dont' last for more than few mins.
I finally thought it could be a power supply/GPU hardware problem, so to find that out, installed Vista 32bit dual boot. To my surprise, everything runs normal in there, shows stock clocks, even OCes well with RivaTuner, everything runs as it's supposed to(didn't change anything in the bios). But I want to run the other 64bit install because I have everything set up there and also I have 8 GB which will go waste in 32bit. I'm guessing it will work normally in a 64bit fresh install. So, this has to be a software issue, but I can't figure out what the issue is. I don't want to reinstall Vista 64bit and all my apps from scratch since that will be a huge waste of time and energy. Does anyone have some points to help me out? Should I try different overclocking tools that might let me clock up from the low clocks(rivatuner's sliders show 0 and are disabled)? ATITool oc'ing doesn't seem to work on Vista 64bit because of unsigned 64bit drivers issue.
Can anyone help?
Edit: GPUZ screenshot http://img122.imageshack.us/my.php?image=gpuzcz3.jpg
Rivatuner monitor http://img122.imageshack.us/my...image=rivatunerkp6.jpg
Can anyone help?
