Na it's a hot running card and furmark is not real world it is a worst case scenario so you are fine. 80C idle does seem a bit high but really I would think about starting to save for an upgrade anyway if I were you.So i recently purchased a PNY 8800gt off the forums, but I've noticed it's been running a bit hot. It idles at 80 degrees and furmark brings it to about 110 degrees. It's a bit worrying, and seems dangerous. Any suggestions?
Changing the fan speed doesn't seem to affect temps at all. It was idling at 80 degrees, 40% fan speed, ramped it up to 100% fan speed, and there was no difference. Probably bad HSF/GPU contact?
EDIT: Actually, I was wrong, I let it idle for a few minutes udner 40% fan speed. Temps went up to 105 degrees.
There are various tutorials and even videos all over the internet mate so run search like most of us have done.In any case, can somebody walk me through step by step on taking apart my card and replacing the TIM?
I replaced the TIM on my card, and it's still running at 80 degrees on idle and >100 degrees on load. Time for aftermarket heatsink?
